I’ll be without internet for a couple of days. However I would like to update volumio (due to issues solved in newer versions). Solution is to connect to an android hotspot and plugin a keyboard and HDMI to use the terminal. Which commands do I need to trigger an OTA update?
The update method in the docs (https://volumio.github.io/docs/User_Manual/System_updates.html) is not an option since via the hotspot I’m unable to reach the volumio webserver.
Thanks!
