Systeminfo, the plugin for Volumio4 (bookworm)
Hello all!
I updated Systeminfo v3.0.14 for Volumio4 based on Bookworm.
Thank you @Wheaten for your help and tests!
What is new?
  • better board detection, even with Volumio HW (Primo, Integro, Motivo…)
  • Firmware detection
  • More info for cpu
  • Software information
And new feature, a hardware benchmark based on sysbench
Enjoy! :wink:
Excellent piece of work! Just one thing I noticed
It’s hard to see the text in run benchmark test button. It’s more or less just white. tested on rPi5 and rPi4.
Best Regards / C
Yes I know. But I don’t know how to change it as the colour is given by volumio UI. I’ll have a look though.
Thanks for the feedback :slightly_smiling_face:
i guess the easiest way would be to have both buttons with green background with white text?
I heard you!
Plus other improvements…
Systemnfo 3.0.15
Enjoy! :wink:
Looks great! Works Great! Thanks!
One of my “must have” plugins.
Best Regards / C
Thanks for adding in the Volumio Boards, really love this little plugin.
Thanks for the plugin update. It works even better than before.
Systeminfo v3.1.1
New interface with live update for CPU load, memory and storage used
Enjoy! :wink:
edit : if the interface doesn’t load after install, reboot your system.
@balbuze Just updated and I got to say this is really well done. This little plugin should appear natively on the system tab of the Volumio operating system.
Thank you for your feedback! :wink:
@balbuze
Great improvement, new layout well received!!
