Volumio Version: 3 (latest)
Hardware: Rivo Plus
DAC: Gustard X26 III
FusionDSP will set attenuation to some level for headroom to avoid clipping.
When turn OFF FusionDSP the level of attenuation will be hold !
Uninstalling FusionDSP will delete the level of attenuation.
Hey.
When FusionDsp is enabled, you enable or disable effect. The attenuation is kept so that you can compare. This is a design choice.
If you want no effect and no attenuation, you can create a preset with no effect.
Or disable the plugin if you don’t need it.
No need to remove it (unless you want to).
I close this post because there’s a dedicated thread for FusionDsp .
Please continue here:FusionDsp : the complete Dsp center for Volumio3!
