I’ve build a Volumio player with a Raspberry Pi4, the 7 inch RP touch screen and the Hifiberry DAC2 pro.
Using a RF usb remote control for controle volume, next track etc.
After installing the GPIO buttons plugin v0.8.1 I’m trying the switch on/of Volumio with a push button normally open/closed using GPIO 17 and a ground pin.
Making en short connection between GPIO 17 and ground does not trigger any event.
lack of substantive knowledge at my side but can someone help me on how to implement it?
Hi dvo! Can you help me with this i bought gpio extension board coz i want to add momentary push button while st400 hat dac is still connected/hook with the raspberry pi 4 b gpio.
Is it working if i hook the button wire to gpio 3 and a GND while dac is connected with the same gpio
