Switch off update
I have use volumio version 3423 and I’m happy with it.
now I see each time when start up that there is an update available and I already
switched it off but still I get this message.
Update v3.429
Hotfix release
  • Timezone configuration fixes
  • State machine improvements and fixes
  • Auto update window configuration
  • Automatic timezone configuration in the wizard
  • Multiroom state synchronization fixes
is there a way to switch it off?
Any solution for this !!
You should be able to turn off automatic updates. Click on the
image menu on the top right of the window and click on
image Scroll down to
and make sure Automatic Updates is turned off. You might have to restart to make the message go away.
Regards,
I mean the message on the screen, each time
when start up i see this message.
There is no way i can switch this of ?
is there a way to switch off the update by sudo, because you cannot use your phone for the time that
update is in the screen I have version 3.423 and want to use this
Each time when I start the app Volumio I get a message update available for 6 sec and must wait before this message is gone even when the settings update is switched off.
I want to use this version, and I don’t want to update, my kids have also access to this app
and now it’s the second time they updated it and the screen and settings were gone.
Thanks for helping
I have been looking forward to this option, too. Sadly, this appears to be unsupported. Nowadays, developers insist that users should participate in an endless loop of updates to provide the developers with constant stream of bug reports on glitches introduced with each new update. Probably, that is why at least some of us must suffer from this annoying update reminder each time the player starts up. Since their lips are sealed, we can file it as a concealed cost of free software. One of many, I suppose.
Absolutely kind regards,
xoxo
Yeah I totally agree.
If there are guests around or kids using the system.
Not sure if its them trying to be helpful or trying to be funny. As everyone (even kids) knows if you update its going to pause whatever is going on and possibly break it.
There needs to be an option to remove this ability to update from the main screen.
Or at least password protect the update process so it cant be done by anyone.
I have removed the icon and the pop-up with a couple of edits to the app-********.js file.
have a look at the second post here
I download the 3.795 and happy with that. Now each time working with the app new upgrade availible. Is there no way to switch this offf?
Even select the time and showtime to 0
No idea what second last version is…
As said… the method I posted above was only tested in 3.695
So the method of editing the app-****.js file in the way that I posted no longer stops the popup in 3.795.
Sorry I do not use that version, you’ll have to tinker yourself
Where can i find this
My very first post replying to you, maybe theres a link there :slight_smile:
