I use rockbox on some old Sansa clip devices and it has a brilliant feature explained here where you can automatically enable sleep on boot and restart the countdown every time you press a key. I think these would be brilliant features to include as options you can turn on in the sleep menu.
I’ve implemented a version of this using Python and mpdcron I posted about here.
