Suggest a Feature Collection
So many suggested Features …
I tried to list them for a better overview:
Implemented Suggestions:
[i]- Changing the Name of Volumio in the WebUI
  • Welcome Sound when Volumio booted
  • Advanced Shutdown (Pressing the shutdown button -> Player stop -> MPD stop -> Device stop)
  • Changelog for every Device in the forum (because many people wanna know why they should upgrade their well running system)
  • “Currently Listen to” Feature
    • -> Facebook
    • -> Twitter
  • Playlist:
    • -> Clear whole Playlist
  • Library:
    • -> Option to disable
  • Support for:
    • -> Spotify
  • Add a Radio Station over the WebUI
    [/i]
I will add new suggested features, please post them as an extra thread!
Last update: 09.07.2015
is it possible to add bluetooth remote controller to volumio?
Superstar customer should unlock color themes, my suggestion is use a name of a song that will make it more music like instead of green, red, blue. Since the main purpose of Volumio is to enjoy music.
Volumio — Standard Color
These colors are named after popular 60-80’s Songs.
Baby Blue — Nice Blue Color
Purple Rain — Nice Purple
Crimson & Clover. — Deep Red Color
Mellow Yellow — Yellowish Color
White Rabbit. — White Color
Fields of Gold. — Gold Color
Orange Crush. — Orange Color
Brown Sugar. — Light Brown
Green River — Darkish Green
Please add Genre search to Qobuz. This would be my #1 complaint. Thank you for your consideration.
Alphabetic sorting of Qobuz lists (currently shown as date added with no option to change)
see:
https://community.volumio.com/t/sort-by-artist-album-with-qobuz/11849/5
It’s nice when the different sorting options are possible in Volumio. Also for favorites in all music services like Qobuz, Tidal Spotify, local flacs etc.
My Spotify playlists are getting too long to be fully displayed in the web UI (truncated after X items). It would be nice if one could load playlists in reverse order, so you would always be able to load the latest X items that have been added to the list. Not sure if the Spotify API supports this, otherwise I perhaps should send this feature request to Sweden :thinking:
Great feature would be set a timer for music (like alarm) and stop music (like sleep timer)
Like for example, my alarm plays at 6.00AM, I’m leaving for work at 07.00AM so if my alarm would stop at 7.00AM that saves me opening the app and stopping the music before going to work…
I would have another alarm at 5.00PM so music would be playing if I enter my home and start cooking :grin:
:v:
Not the cleanest solution, but it will do the trick.
create a cronjob for it and execute: /usr/local/bin/volumio toggle
sudo apt-get update
sudo apt-get install cron
crontab -e
# Start playing at 06:00 on weekdays
0 6 * * 1-5 /usr/local/bin/volumio play
# Stop playing at 07:00 on weekdays
0 7 * * 1-5 /usr/local/bin/volumio pause
# Start playing at 17:00 on weekdays
0 17 * * 1-5 /usr/local/bin/volumio pause
you can also use stop if your playing a radio station
would love to be able to boot from SSD instead of SD card
I nice surprise would be the option to search for „years“ I.e 1984, 2012. any chance?
Thx for Volumio
Thanks,
But for now I installed moode audio in my bedroom…
Still want this feature on volumio tho :wink:
Now the raspberry pi 5 is announced, are there plans to release an update for it?
I pre-ordered one and it would be amazing if Volumio will support it.
So I hope there will be an update soon for raspberry pi 5.
Yours sincerely,
Laurens
Well,
Volumio first needs to get it’s hands on a rPi5 and see what the impact is. Then they can make a plan for it.
I pre-ordered one too but it’s a overkill to run Volumio on.
(5A, Mandatory fan,…)
This is the first RPi I might actually like, but a fan on an audio device? Definitely a no-go for me. I’ll pre-order one anyway in the hope for a good passive-cooling accessory, which no doubt will be available at some point soon.
Huge fan of Volumio, best player for my CD collection that I ripped some years ago. As I sorted all my music in folders by genre, I only use the browsing feature (never the library).
However, there is a feature that I believe could be of some use for numerous users :
1 - Option to select, that would :
a- stop the music at the end of the files of the present folder (= actual behaviour)
b- OR continues playing with the first file of the next folder (continuous playback, no need to “guess” what to play next)
2- New button on the current playing page, that swaps directly to the first file of the next folder (as the triple arrow in the Poweramp app on android, for exemple)
On the app, I am quite annoyed with the Android “previous button”, that goes straight to the “useless” strartup page (for people who have 1 device). It could be more usefull to be able to use this android button to go 1 folder upwards while browing the music collection (and the same way, to close the options menu too).
Thanks !
ok, no news… I think I’ll try with moOde !
Can you read and display the covers from the individual MP3 files? It would also be nice if the lyrics could be extracted from the files and displayed upon request. I have added covers and lyrics to all my MP3 files, and it works great on my iPhone X.
Can you move the Bluetooth Music to the free version please.
