Stuck in boot loop for the 3rd time now.
I have Volumio on a Raspberry Pi 3b+ and the official 7" touchscreen and for the 3rd time in the past few weeks I’m having this problem. I turned on the Pi and the screen stayed blank so I used the webUI and all the plugins are deactivated. I reactivated them and it just froze in an endless loading icon. So I hard reset it and now it’s stuck in a boot loop. This will be the 3rd time I have to completely reflash the SD Card and I am so far beyond frustrated it’s ridiculous. I’ve tried multiple Pis, power sources and SD Cards with no change. I have at least 6 other Pi projects running at various times and I have never once run into this problem with a single other piece of software. So I figured I’d take a stab here and see if anyone has any ideas before I say screw it and move on to Moode or RuneAudio. I’ve had so many little problems with Volumio that I was willing to deal with and just chalked them up as quirks but this may be the nail in the coffin. Thank you very much in advance to anyone that may have an idea or insight.
Just happened to me. Need to take an image to avoid system rebuild
