Streaming with http referer - please help
Rpi3b with Volumio.
I am trying to stream a radio station which looks for http referrer: Would like to know how I can add a radio stream URL with http referer on Volumio or the CLI input to get the stream playing with output to my DAC.
vlc --http-referrer=‘http://www.WEBSITE.com’ ‘http://xxx.xx.xxx.xxxx:8002/1
Yes of course. This is what the DKFM Classic stream URL looks like:
http://142.44.131.253:8013/listen.pls?sid=1&t=.pls
Thanks…
Just to be clear, I am trying to play the following stream that works on a browser window:
http://www.tamilradios.com/embed/index.php?src=http://212.47.243.160:8002/1
The server with IP is looking for a http referrer field starting with “http://www.tamilradios.com”. I would like to know how to get this type of stream playing on Volumio.
That last part is the stream URL, but it’s a private stream that needs a username and password.
Thanks. That stream URL when coupled with the http referer plays from the browser as a public stream, without any userid or password. I am just looking at a way to play it on Volumio.
Yeah, the tamilradios site must pass the authentication credentials to the stream server.
Without those credentials and knowing how to pass them in a URL that works for Volumio I think you’re stuck.
Thanks.
I just managed to install mplayer on Volumio and piped the curl output as below. The radio stream with http referer works.
curl --referer http://www.tamilradios.com http://212.47.243.160:8002/1 | mplayer -vo null -ao alsa:device=hw=2.0 -quiet -cache 2048 -
Now, if I can find a way to play this from the Volumio webUI, I can complete the set up for my friend. Any pointers on that? Thanks.
You might find some help in these topics
https://community.volumio.com/search?q=curl
@miovol Have you seen this? I was going to suggest using the ~/.curlrc file as a hack, but couldn’t get it working and came across this.
EDIT: You could spin up a simple proxy using node for this. And then use this url to with mpd.
This is just a PoC, but feel free to expand it into something more feature full!
const http = require('http');
const proxy_port = 2585;
http.createServer(onRequest).listen(proxy_port);
console.log(`Server up and listening on ${proxy_port}`)
function onRequest(client_req, client_res) {
  const options = {
    hostname: '212.47.243.160',
    port: 8002,
    path: '/1',
    method: client_req.method,
    headers: client_req.headers
  // Add the required header
  options.headers.Referer = 'http://www.tamilradios.com'
  const proxy = http.request(options, function(res) {
    client_res.writeHead(res.statusCode, res.headers)
    res.pipe(client_res, {
      end: true
  client_req.pipe(proxy, {
    end: true
@ashthespy
Thanks for this. I still don’t get how to get the proxy output to work with mpd. I will give it a go…
So here is something quick to get you started…
You could use it as follows:
cd ~
https://gist.githubusercontent.com/ashthespy/784394a64601b095724a724694a512d6/raw/0e7f1abb92993178129aae22d659b4affbeb7d28/volumioWebRadioProxy
chmod +x volumioWebRadioProxy
./volumioWebRadioProxy
Then add a webradio using the normal way, but point it to http://localhost:2585/tamilradios
If I were you, I would make this a proper service and launch it via systemd to ensure it’s always up. You could also extend the script to add other radios that require any custom stuff.
HTH,
That really helps, @ashthespy, now I understand how to use the proxy you suggested. Thanks much.
@ashthespy, Thanks again for your time with this! Compared to using curl, this is a scalable solution where I have used the same proxy for other radio stations as well (passing parameters to the node.js script). Also it is now running as a service via systemd and usable from within LMS environment too.
Glad it worked out, If you happen to have it as a gist (and are willing to share) please do add a link, it might help someone else in the future :slight_smile:
