streaming to bluetooth headset?
I have installed the latest Volumio version on a Pi 3B+ with a standard Pi 7" touch screen attached and a HifiBerry DAC and so far everything worked quite nicely, even though I am completely new to the Pi and this is my very first project using it.
I would love to be able to stream from my NAS to my Bluetooth headset (Sennheiser Momentum). Since the 3B+ has built-in BT HW I would assume that this should be possible but I am lacking deeper familiarity with Linux and the Pi ecosystem in particular. I found a few locations dealing with sending from the Pi to a BT speaker (which IMHO should be similar) but those descrptions were either for an elder or smaller Pi’s using a BT dongle or for a rather old Volumio version. I also understand that there seems a BT plugin in the making but I got lost on how to install it (… drag it to the upload section ???).
Is there a newby-compatible description available (or someone willing to share or create one) on how to achieve this using newer Pi and Volumio versions? Any help or pointers highly appreciated!
