How i can stream music from YT from Android devices? From IOS devices works fine with airplay, but i want with Android also
Best options are to use bubbleupnp or mconnectlite apps which can stream to volumio, another option is to use Bluetoothβ¦
Thank you, I also think that using Bluetooth is a good idea.
Iβm using Airaudio. When activated it streams all audio from android device(youtube, deeezer, spotify, local musicβ¦) via wifi to upnp/dlna device.
Works flawless. Your android has to be rooted thoughβ¦
I can recommend the MAG425A prefix and I can say that I am very pleased with its functionality. (details on this device can be found at https://www.infomir.us/products/mag425a.html). This device can play 4K video even with low speed network connection, has built-in Chromecast function
ΠΠ΄ΡΠ°Π²ΡΡΠ²ΡΠΉΡΠ΅, ΠΈΠ·Π²ΠΈΠ½ΠΈΡΠ΅ Π·Π° ΠΊΡΠΈΠ²ΠΎΠΉ Π°Π½Π³Π»ΠΈΠΉΡΠΊΠΈΠΉ. ΠΠΎΠ΄ΡΠΊΠ°ΠΆΠΈΡΠ΅ ΠΊΠ°ΠΊ ΡΠ΅ΡΠ΅Π· Bluetooth ΠΈΠ»ΠΈ Wi-Fi ΠΏΠ΅ΡΠ΅Π΄Π°ΡΡ Π·Π²ΡΠΊ Ρ Π»ΡΠ±ΠΎΠ³ΠΎ ΠΏΡΠΈΠ»ΠΎΠΆΠ΅Π½ΠΈΡ Π·Π°ΠΏΡΡΠ΅Π½Π½ΠΎΠ³ΠΎ Π½Π° Π°Π½Π΄ΡΠΎΠΈΠ΄ Π½Π° raspberry volumio. Hello, sorry for the curve English. Tell me how to transfer sound from any application running on Android to raspberry volumio via Bluetooth or Wi-Fi.
ΠΠΎΠΎΠ±ΡΠ΅ΠΌ Π½ΠΈΠΊΡΠΎ Π½Π΅ ΠΏΠΎΠ΄ΡΠΊΠ°Π·Π°Π» ΠΏΠΎΡΡΠΎΠΌΡ ΡΠ°Π·ΠΎΠ±ΡΠ°Π»ΡΡ ΡΠ°ΠΌ. ΠΡΠΈΠ»ΠΎΠΆΠ΅Π½ΠΈΠ΅ AirMusic (Π±ΡΠ²ΡΠ΅Π΅ AirAudio) Π½Π΅ΠΎΠ±Ρ ΠΎΠ΄ΠΈΠΌ Android 10 Π»ΠΈΠ±ΠΎ Android 5+ ΠΈ root. In general, no one prompted so I figured it out myself. The AirMusic app (formerly AirAudio) requires Android 10 or Android 5+ and root.
