Hi, i am having the same issue. How do I access "/etc/wpa_supplicant/wpa_supplicant.conf " on my Rpi4? Thanks for your support! Also, do you know the country code for the USA?
Hello all,
Sorry I’m very thick when it comes to coding. How do I change the country code as I’m in Australia and the WiFi keeps dropping out?
I’ve put in sudo nano etc/wpa_supplicant/wpa_supplicant.conf and a list come up but I’m not sure what to do next?
Thanks.
Thank you I’ll give it a go. It is very annoying that I have to even do this as you’d think this would be as part of the setup with paying €69 a year for Volumio.
I also benefited from this solution, as my Volumio device mysteriously disappeared from the network intermittently after I swapped my AP.
It appears to be a known issue in Raspberry PI devices, and it would be a useful feature to support selection of the country code through the networking section of the settings menus, at least when run from one of the images targeting RP.
