Hey everyone,
I’ve been using Volumio more than 2 years. Just last year around December I started using Qobuz and before that and in parallel Spotify, also throughout the whole time I’m using my CD library on the NAS. Latter is working without any issues.
Since a couple of weeks Qobuz and Spotify work only occasionally. Or they work but after two or more skips or title-changes everything stops responding. It’s nothing heat related.
please post a log when this is happening.
If it helps, I can report that I’ve been listening to Qobuz for almost two hours straight with no issue.
- Do you have infinity play enabled, if yes turn it of and try again
- Can you clear the queue and load a single album, is this working?
I see multiple errors that mpd has stopped.
Mar 04 19:49:35 volumio-pl volumio[860]: error: Could not get QOBUZ Stream URL: undefined
Mar 04 19:49:35 volumio-pl volumio[860]: STREAMING PROXY: Error: Failed to retrieve proper real streamUrl: {"success":false,"error":"Could not get QOBUZ Stream URL: undefined"}
Mar 04 19:49:37 volumio-pl systemd[1]: mpd.service: State 'stop-sigterm' timed out. Killing.
Mar 04 19:49:37 volumio-pl systemd[1]: mpd.service: Killing process 1704 (mpd) with signal SIGKILL.
Mar 04 19:49:37 volumio-pl volumio[860]: error: MPD error: Error: read ECONNRESET
Mar 04 19:49:37 volumio-pl systemd[1]: mpd.service: Main process exited, code=killed, status=9/KILL
Mar 04 19:49:37 volumio-pl systemd[1]: mpd.service: Failed with result 'timeout'.
Mar 04 19:49:37 volumio-pl systemd[1]: Stopped Music Player Daemon.
Infinity play was not enabled.
Unfortunately, the input does not respond anymore. No clue why.
I cleared the queue. That worked.
But as soon as selection from streaming sources need to be selected the input is not responding.
Qobuz plays occasionally. But only a few titles until it stops responding.
