Volumio Information
Volumio Version: v2.915
Hardware: RPI4
DAC: Hifiberry Digi+
Hello everyone,
constant noise is audible from the speakers when no sound is played (from a distance of approx. 50 cm). It makes no difference whether I connect the RPI via USB or via optical cable (HiFiBerry Digi+) to the amplifier (Rotel RA 1592).
If I switch to another channel, the noise is no longer present. Likewise, the noise is also perceptible when headphones are plugged in.
I also tried to reduce the gain within alsamixer and checked all my configs. No matter what I do, the noise is still present
Was anybody confronted with the same issue and found a solution?
Thank you in advance!
Cheers,
ToKillTime
