SSL Root certifcate validation for Podcast plugin | Fixing the Breakage from the AddTrust External CA Root Expiration
Since few days, I have some podcasts that were perfectly working that cannot be played anymore due to certificate non validated.
It seems that one of the certificates has changed 4 days ago and that gnutls is not managing it properly.
Here the check on the ssl certficate for one of the concerned URL :
https://www.sslshopper.com/ssl-checker.html#hostname=https://rf.proxycast.org/2bac8238-7f93-4283-8ddc-2f330874d720/20108-05.05.2020-ITEMA_22334674-3-1779455909.m4a
Related post that explains the issue :
https://www.agwa.name/blog/post/fixing_the_addtrust_root_expiration
So I think there is a need to do some updates on volumio to handle this otherwise we will have to wait for all servers using this certificate to hopefully fix it.
Cheers,
Pierre.
Good find…
This should do the trick (for now! And as usual caveat emptor)
#!/usr/bin/env bash
# Patch certificates
# https://support.sectigo.com/articles/Knowledge/Sectigo-AddTrust-External-CA-Root-Expiring-May-30-2020
if [[ "$EUID" -ne 0 ]]; then
  echo "Please rerun as root"
  exit 1
fi
if [[ -f /etc/ca-certificates.conf ]]; then
    sed -i "s|^mozilla/AddTrust_External_Root.crt$|# Disabling for now to fix Sectigo-AddTrust-External-CA-Root-Expiring-May-30-2020\n# mozilla/AddTrust_External_Root.crt|" /etc/ca-certificates.conf
    update-ca-certificates
fi
I think this is not a good idea: any manual intervention will prevent updates to apply correctly
I also have some issues with this web radio
https://nr4.newradio.it/proxy/marcroma?mp=/stream&1591189448327
it used to works till few days ago, now I get some errors with certificate trying to play it
I would agree but I did the change in /etc/ca-certificates.conf anyway.
Difficult to negotiate with 4 and 6 years old children who wants their favorite podcast. :slight_smile:
