Hell together
I tried to configure ssh as described on page: https://volumio.github.io/docs/User_Manual/SSH.html, but unfortunately no one of these options is working.
Is there another way? How does the ssh file need to look like?
[EDIT]
trying to open /DEV shows that buttons to enable are even hidden/deactivated
once you navigate to volumio.local/dev
click ENABLE
there won’t be any confirmation that it is on but it is.
now open up your commandline tool
type
ssh volumio@volumioipaddress
then you will get a prompt for a password
type
volumio
Thank you for the reply, but I need to state that it still does not work. Even after a reboot.
