I am using a minidsp SHD device. It is a room correction system using dirac and features a dac and additional an undefined arm board with volumio on it. There is a plugin for Volumio to run squeezelite. The version is v1.8.7-999. It is compiled with libwiringPi. The dac is supposed to be connected via I2S. I managed to compile the library and get the plugin to run.
Now The Question:
squeezelite -l gives me several devices:
null - Discard all samples (playback) or generate zero samples (capture)
default:CARD=sndsun8ii2sdac - snd-sun8i-i2s-dac, - Default Audio Device
sysdefault:CARD=sndsun8ii2sdac - snd-sun8i-i2s-dac, - Default Audio Device
dmix:CARD=sndsun8ii2sdac,DEV=0 - snd-sun8i-i2s-dac, - Direct sample mixing device
dsnoop:CARD=sndsun8ii2sdac,DEV=0 - snd-sun8i-i2s-dac, - Direct sample snooping device
hw:CARD=sndsun8ii2sdac,DEV=0 - snd-sun8i-i2s-dac, - Direct hardware device without any conversions
plughw:CARD=sndsun8ii2sdac,DEV=0 - snd-sun8i-i2s-dac, - Hardware device with all software conversions
default:CARD=Codec - H3 Audio Codec, - Default Audio Device
sysdefault:CARD=Codec - H3 Audio Codec, - Default Audio Device
dmix:CARD=Codec,DEV=0 - H3 Audio Codec, - Direct sample mixing device
dsnoop:CARD=Codec,DEV=0 - H3 Audio Codec, - Direct sample snooping device
hw:CARD=Codec,DEV=0 - H3 Audio Codec, - Direct hardware device without any conversions
plughw:CARD=Codec,DEV=0 - H3 Audio Codec, - Hardware device with all software conversions
If I take the sndsun8ii2sdac I only get noise which turns on and of if I start palying or stop.
I I take the H3 Audio Codec I get nothing.
It is the same, when I use the latest squeezelite from sourceforge.
Any idea why this is so?
The Volumio player works fine, but I have a complete Squeezebox environment so I prefer to use squeezelite.
Any help would be appreciated.
Greets Christian
