Hello board,
I’m using Volumio on raspberry pi 3 with DAC, installed squeezelite and want to use it either directly or via LMS.
While playing around with my squeezelite config, I found a description how to setup two independent mono channels on 1 sound card using asound.conf. Which fits perfectly for my scenario (I’ve got two mono speaker from different rooms connected).
And here are my questions:
- that multi room config requires 2 instances of squeezelite to be started. works fine from command line. but I’d like to start and stop them through volumio plugin web page. Where is the script that gets called when switching the squeezelite plugin on/off? Can this be replaced to call another script instead?
-In order to be able to use squeezelite and volumio at the same time, I’d like to configure volumio to use a virtual soundcard configured in asound.conf. Is that possible? how?
this is how my /etc/asound.conf looks like
pcm.snd_card {
type hw
card 1
device 0
pcm.dshare {
type dmix
ipc_key 2048
slave {
pcm "snd_card"
channels 2
pcm.room1 {
type plug
slave {
pcm "dshare"
channels 2
ttable.0.0 1
ttable.1.0 1
pcm.room2 {
type plug
slave {
pcm "dshare"
channels 2
ttable.0.1 1
ttable.1.1 1
pcm.both {
type plug
slave {
pcm "dshare"
channels 2
ttable.0.0 1
ttable.1.0 1
ttable.0.1 1
ttable.1.1 1
Thanks,
Rene
