I have a small problem with Spotify,the plugin is active, I have configured the plugin.
the home button does not appear. why?
Can you give us more details please? What is the “home button” you refer to?
SETTINGS—>MY MUSIC
news?
if i clik on “My Playlist”, Volumio do nothing
Hi!
With this plugin you can only access to your spotify playlists you made in Spotify. Nothing else. If you dont have any playlists created in Spotify then you can not use the plugin.
I think it is a bit late now but if this response can help anyone else…
but why i don’t see the icon of spotify?
some idea?
i had removed all and factory defoult of volumio… but i don’t see the icon
