Hi I can’t login into Spotify plugin, wont accept my username and password even though reset password, and shutdown several times
Help please
Which plugin are you using. As one of them needs a family account. and the other you need to grant access.
Or ypu’re already logged in on a different machine. (PC, Phone, Tablet,…)
Hi
Just using the standard plugin, have premium family, and made sure logged out of all phones ect, tried my wife’s login, same issue
Weirdly I can play Spotify through Spotify connect though
Thoughts
Sean
Hello
I have the same problem since a couple of hours. Yesyterday night it was working fine.
Hi
Thanks hopefully it will be fine tomorrow then
Yep, seems related to Spotify.
Unless Pfizer makes you forget your credentials…
