problem is volumio 3 does not support keyboard plugin in kiosk mode right? has that been solved?
thanks!
thanks!
No solution yet for the onscreen keyboard yet.
Ok, question - will this plugin be available for free or for premium subscribers only?
Free of course. Thought there were no doubts about that…
Can I participate if there’s a test? I don’t see it in the plug-ins
If there is a chance to get on the beta testing list please add me would love to. I have three volumio units all excited for this to be working again :).
I will love to be a part of beta testing as well for pi4b, I have a premium account and was using it just for Spotify, Spotify connect works but somehow it sounds really bad, So a working plugin is make or break for me.
I would also like to try whatever fix you have put together. I only use my pi zero w and volumio to play Spotify.
Same, I’m premium and I will like to be a beta test. Thank’s Guy’s !
Nice work, appreciate the effort
Update: work is almost done, plugin works really nice and it’s very well polished.
Only 2 issues remaining:
Once fixed, will release the plugin and provide wannabe testers with instructions
Can test. Running pi with Digione hat. Thanks so much for getting this back up!!
Same, I wanna be part of the testing phase !
These are very good news, I am looking forward.
You know, there are commercial products out there in the market, like my JVC autoradio. I purchased it two years ago, because it is (was) able to connect to spotify.
Doesn’t work anylonger. There must be another products with this problem. Up to now, I dont have information about a fix/new version from JVC.
Thanks for all the great work and your efforts!
Franz
like the Denon DBT 1713UD.
paid 600 euro for it. within 3 years it became a piece of junk, because Denon wouldn’t provide updates.
All streaming function stopped working, because the platform changed:
Would be happy to test if there is ‘space’ available in the group for another wannabe tester.
Another one here to add to your tester list. I was using Spotify with Volumio a lot.
Thanks for your efforts
Steve
My 6 and 9 years old girls have a Volumio each, they will thoroughly test I promise, every single feature, and if it doesn’t work they will break my balls, so you better fix quick!!
I upgraded. You were 100% right. I find the overall experience much better than 2
Also donated something now.
available for testing it
