Spotify wont accept my username and password again
Since 2 hours i am not able to have Spotify working.
I can’t connect the spotify it wont accept username or password.
Is it a problem of Spotify ?
same here
yep same here.
Same problem here aswell… Spotify works on all other platforms I got
yeah it’s with the Volumio servers
Where have you seen Spotify uses Volumio servers? :thinking:
As far as I know everything runs through Volumio servers, Qobuz, Tidal, … So I expect Spotify will do to. If not why is Spotify as integration/plugin in Volumio falling and not with other applications/integrations?
Just a coincidence? If so I stand corrected
Try disable the plugin - then reenable and log on
Worked for me
Br
Josef
Not Spotify…
Already did that, still unable to login.
As stated with another platform, using the the same source for a plugin it works, that’s why i think/thought its related to Volumio (servers?)
Already done and also uninstall plugin, restart Volumio, install plugin … connection failed. Restart volumio. connection failed etc…
No way
Same problem here. Restart or switching plugins on/off do not fix the issue. Could it perhaps be a change in the Spotify api that Volumio uses to communicate with the service?
Now same problem here…
+1
Spotify is gone…
My guess.
Either Spotify is having a big problem…
Or Spotify stop client using the old API used in spop used in the plugin…
I can’t test now. If first hypothesis, everything should be ok soon …
But in the second case…
site 104.199.65.124 is still alive but errors out with 409 " the request could not be processed because of conflict in the request. The port 4070 seems closed.
Let’s hope it start running again:
info: SpopD Daemon Started
2022-05-16 20:05:19 [SPTF] 18:05:19.327 I [offline_authorizer.cpp:297] Unable to login offline: no such user
2022-05-16 20:05:19 [SPTF] 18:05:19.336 I [ap:1752] Connecting to AP ap.spotify.com:4070
2022-05-16 20:05:19 [SPTF] 18:05:19.373 I [ap:1226] Connected to AP: 104.199.65.124:4070
2022-05-16 20:05:19 [SPTF] 18:05:19.724 E [ap:3953] Connection error: 409
2022-05-16 20:05:19 [WARN] Login failed: User needs a premium account
2022-05-16 20:05:19 [ERR ] Could not get the playlist container.
same here: Spotify disappeared from the sources this afternoon - could Volumio pls provide some infos?
Spotify works nicely on native app on ipad and iphone though, so Spotify isn’t generally out of service.
tx in advance
Device: Pro-Ject Stream Box S2 Ultra
I think Balbuze already provided feedback. Let’s wait and hope the API is still alive at Spotify.
Same problem here
Same
