I am having a bit of trouble getting Spotify to work with Volumio 2. I am able to sign in, search and select songs. When I hit the play button, no music plays but i get a message in the top right that says the music is playing. When I change the volume, the timer on the left changes place in the song, like it is supposed to be playing. I have a Spotify Premium account.
I must say I have not used Volumio without a DAC, so I’m not sure how to check if sound should be output.
Did you verify that the connection you are using (headphone jack/HDMI) is selected in ‘playback options’ in the menu? I presume yes, but just checking
I believe you should be able to check which soundcard (index) spop is using and cross reference that with the command ‘aplay -l’ (which lists your soundcards. I can’t really search the forum now (@work), but maybe someone else can assist, else I’d have to check this weekend (somewhere)
