I installed spotify into volumio, connected it to spotify. I do see the option in spotify , but i get no sound out.
playing files from my nas works fine using volumio.
Any ideas?
Any ideas?
Yes, I have an idea: send a log so we’re not completely blind and forced to play digital roulette, a game I’m definitely not skilled at
I was just running into this! For anyone struggling to get it to connect, sometimes just toggling the plugin off and on in the settings—or doing a full ‘Logout/Login’ inside the Spotify plugin menu - fixes that weird authentication hang. It’s a bit of a chore, but it usually beats a full reinstall of the OS.
