My setup:
Raspberry pi 3
IQ Audio DAC
Waveshare 4" screen
I was able to install Volumio, login to the Pi, install the config for the screen so it displays the Volumio display, and install the Spotify plugin.
I noticed there are two plugins: one that works through the Volumio interface and one that allows streaming directly from Spotify to Volumio.
I do like the second app, BUT it does not display anything on the display so that option is out.
The other Spotify Plugin does not seem to work well at all. I tried through my laptop, iphone, and even spending money for the Volumio iphone App.
My issues:
Spotify does not return genres and playlists. Once I get 1-2 layers in, it will not move ahead. Example: I select “Rock” as a genre and it doesn’t do anything.
I press play on the first song of an album and it does not continue playing. Is this intended? How do I fix that?
Be able to select a song in Spotify on my iPhone and have it play on Volumio.
I want the contents of the song to display on the 4" screen.
I want to press play on the first song and it continue through the end of the album and onwards.
Spotconnect: This achieves goal 2 and a bit of 1. The interface is not great at achieving 1. Does not achieve 3.
Spotconnect2: Goal 1 and 3 work as they should (because you are in the Spotify app itself). Goal 2 is NOT achieved.
How can I achieve all 3 goals? Also: is there a sound quality difference between the spotconnect and spotconnect2?
Both volspotconnect and volspotconnect2 achieve the same thing - Spotify Connect So that takes care of Goal 1.
Both of them should let you connect to the Volumio device, select a song from any Spotify client and have it play on the device. And hence, both will mimic the official Spotify clients behaviour when it comes to Goal 3.
With regards to Goal 2 - both the plugins will also update the WebUI and display the album art. Does it work on the normal display?
For your last question about sound quality, Both of them should be the same given they both use the same Spotify stream, but volspotconnect2 gives you direct hardware volume control if your DAC supports it. Also volspotconnect2 is the actively developed one, and has support for newer Spotify features such as radio and dailymixes.
Interesting discovery:
When I open the Spotify app on my iPhone, select a song and press Play. I then select the icon at the bottom left of the app to “connect to a device”. Here I see Volumio: I select it and I the music plays through Volumio. However, no album/artist/info is sent. The display does NOT display any information: no song infor, no album, no artist, nothing. Note: Under Volumio it says “Spotify Connect”.
However, if I instead select “More Devices / Airplay and Bluetooth” and then select Volumio it works. The song, artist, album information etc is all sent and I see it displayed on the 4" display.
Again, does it work on a normal WebUI from your browser?
You might have to check with the plugin that handles the display on your smaller screen - is it just the touch display plugin?
Thank you for your help.
The Web UI does NOT display the album/artist/song etc information when using the Spotify Connect app.
Process: Open Spotify, play song, select Spotify Connect, the 4" Waveshare display does not display any information. I logged into volumio.local on my iPhone and laptop: no information.
I then select Volumio under Airplay and it displays on the 4" Waveshare display and on the iphone/ laptop in volumio.local.
May 01 23:38:01 volumio volumio[1094]: [Vollibrespot] : Loading track "Bohemian Rhapsody" with Spotify URI "spotify:track:6tqmI7wZXTo2Frur1hWXNU"
May 01 23:38:03 volumio volumio[1094]: [Vollibrespot] : Track "Bohemian Rhapsody" loaded
May 01 23:38:03 volumio kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
May 01 23:39:05 volumio sudo[1402]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
May 01 23:39:05 volumio sudo[1402]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:05 volumio sudo[1404]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
May 01 23:39:05 volumio sudo[1402]: pam_unix(sudo:session): session closed for user root
May 01 23:39:05 volumio sudo[1404]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:05 volumio sudo[1404]: pam_unix(sudo:session): session closed for user root
May 01 23:39:05 volumio volumio[876]: info: CoreCommandRouter::volumioGetVisibleSources
May 01 23:39:05 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
May 01 23:39:05 volumio volumio[876]: info: CoreCommandRouter::volumioGetState
May 01 23:39:05 volumio volumio[876]: info: CoreStateMachine::getState
May 01 23:39:05 volumio volumio[876]: info: CorePlayQueue::getTrack 0
May 01 23:39:05 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
May 01 23:39:05 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
May 01 23:39:05 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
May 01 23:39:05 volumio sudo[1421]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
May 01 23:39:05 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
May 01 23:39:05 volumio volumio[876]: info: Listing playlists
May 01 23:39:05 volumio sudo[1421]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:05 volumio sudo[1421]: pam_unix(sudo:session): session closed for user root
May 01 23:39:05 volumio sudo[1424]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
May 01 23:39:05 volumio sudo[1424]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:05 volumio sudo[1424]: pam_unix(sudo:session): session closed for user root
May 01 23:39:05 volumio volumio[876]: info: No input data
May 01 23:39:10 volumio volumio[876]: info: CoreCommandRouter::getUIConfigOnPlugin
May 01 23:39:11 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: system , getAdvancedSettingsStatus
May 01 23:39:11 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: network , getInfoNetwork
May 01 23:39:11 volumio sudo[1448]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ethtool eth0
May 01 23:39:11 volumio sudo[1448]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1448]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio sudo[1461]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
May 01 23:39:11 volumio sudo[1461]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1461]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio sudo[1475]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
May 01 23:39:11 volumio sudo[1475]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1475]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio sudo[1486]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig wlan0
May 01 23:39:11 volumio sudo[1486]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1486]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio sudo[1499]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
May 01 23:39:11 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: network , getWirelessNetworks
May 01 23:39:11 volumio sudo[1499]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1499]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio sudo[1503]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
May 01 23:39:11 volumio sudo[1507]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwlist wlan0 scan
May 01 23:39:11 volumio sudo[1503]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1507]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1503]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio sudo[1507]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio volumio[876]: An error occurred while scanning: Error: Command failed: sudo /sbin/iwlist wlan0 scan
May 01 23:39:11 volumio volumio[876]: wlan0 Interface doesn't support scanning : Network is down
May 01 23:39:11 volumio volumio[876]: Cannot use regular scanning, forcing with ap-force
May 01 23:39:11 volumio sudo[1526]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iw dev wlan0 scan ap-force
May 01 23:39:11 volumio sudo[1526]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:11 volumio sudo[1526]: pam_unix(sudo:session): session closed for user root
May 01 23:39:11 volumio volumio[876]: command failed: Network is down (-100)
May 01 23:39:11 volumio volumio[876]: Cannot use fallback scanning method: Error: Command failed: /usr/bin/sudo /sbin/iw dev wlan0 scan ap-force
May 01 23:39:41 volumio volumio[876]: info: CoreCommandRouter::volumioGetState
May 01 23:39:41 volumio volumio[876]: info: CoreStateMachine::getState
May 01 23:39:41 volumio volumio[876]: info: CorePlayQueue::getTrack 0
May 01 23:39:41 volumio volumio[876]: info: CoreCommandRouter::volumioGetQueue
May 01 23:39:41 volumio volumio[876]: info: CoreStateMachine::getQueue
May 01 23:39:41 volumio volumio[876]: info: CorePlayQueue::getQueue
May 01 23:39:41 volumio sudo[1566]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
May 01 23:39:41 volumio sudo[1566]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:41 volumio sudo[1566]: pam_unix(sudo:session): session closed for user root
May 01 23:39:52 volumio volumio[876]: info: CALLMETHOD: system_controller system sendBugReport [object Object]
May 01 23:39:52 volumio volumio[876]: info: CoreCommandRouter::executeOnPlugin: system , sendBugReport
May 01 23:39:52 volumio sudo[1603]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig
May 01 23:39:52 volumio sudo[1603]: pam_unix(sudo:session): session opened for user root by (uid=0)
May 01 23:39:52 volumio sudo[1603]: pam_unix(sudo:session): session closed for user root
May 01 23:39:52 volumio sudo[1620]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl -p 7
May 01 23:39:52 volumio sudo[1620]: pam_unix(sudo:session): session opened for user root by (uid=0)
Could you try the following - start capturing logs with
sudo journalctl -f | grep "spot\|vollibre"
Then disable and enable the plugin from the WebUI, and then connect and play something.
I wanted to provide you with an update. I swapped out the 4" display for a 7" display and started with a fresh volumio install.
I installed Volumio, updated the config file for the display, installed the display app in Volumio, installed Spotifyconnect2.
Everything works exactly as planned!
In Spotify, I can now select Spotify Connect and all information is displayed on the screen. I had to change the volume setting to “Software” to allow me to control the volume on the phone.
