Hey I have a weird problem with my Volumio. When I start my Volumio it works fine. I can connect it with my Spotify-account and I can control it. But after a couple of Songs 2-3 it randomly pauses the sound, when I try to restart it from my desktop app Spotify says that there is no device to connect, while the Volumio says that he is playing. When I press the Play/pause button on the Volumio it starts Spotifay on my pc and the sound comes out of the headphones. So I can control Spotify from the Volumio page but I can’t get it to play again. A reboot fixes the Problem for 2-3 songs. Any Idea how to fix that?
Encountered the same problem several times. Every now and then do not have volumio available on spotify. When I try to play a webstation (radio) or songs from drive it works. After restart of volumio it is available in spotify again. Very strange problem
Verstuurd vanaf mijn SM-G935F met Tapatalk
If your using Spotify Connect - with volspotconnect2 please share logs.
Also if you are able to track down the issue - github.com/balbuze/volumio-plugins would get you faster response
