Spotify/ Spotify Connect issue
I have a Problem with the Spotify Connect and possibly with Spotify Plugin. I can listen fine to Spotify with the spotify app for a few hours. Then it turns off and in the Webinterface of Volumio it stays on the same song and goes well above the length of the song but doesn’t output any audio. I then have to turn off the Spotify Connect plugin and back on and it works again. When i stop a song i can still see the volumio about 30 minutes after i stopped the song in spotify connect on my phone and PC. After that it disappears and can not be found. To fix this i have to restart the spotify connect plugin and it works again.
Versions:
Volumio 2.586
Spotify 1.3.5
Volumio Spotify Connect2 0.9.5
This is the log from when it stopped playing. I am not sure whats happening here but maybe someone can help me.
Jun 08 13:25:58 volumio volumio[947]: [SpotifyConnect] Sink released
Jun 08 13:25:59 volumio volumio[26830]: [Vollibrespot] : Loading track “The Feel Good Drag” with Spotify URI “spotify:track:5sTVykpRs4eiZKn96bZogj”
Jun 08 13:25:59 volumio volumio[947]: [SpotifyConnect] Pushing metadata Vollibrespot: true
Jun 08 13:25:59 volumio volumio[947]: info: CoreCommandRouter::volumioGetState
Jun 08 13:25:59 volumio volumio[947]: info: CoreStateMachine::getState
Jun 08 13:25:59 volumio volumio[947]: [SpotifyConnect] Currently active: volspotconnect2
Jun 08 13:25:59 volumio volumio[947]: [SpotifyConnect] Pushing new state :: true
Jun 08 13:25:59 volumio volumio[947]: info: CoreCommandRouter::servicePushState
Jun 08 13:25:59 volumio volumio[947]: info: CoreStateMachine::syncState
Jun 08 13:25:59 volumio volumio[947]: info: CoreStateMachine::pushState
Jun 08 13:25:59 volumio volumio[947]: info: CoreCommandRouter::volumioPushState
Jun 08 13:25:59 volumio volumio[947]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Jun 08 13:25:59 volumio sudo[23885]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Jun 08 13:25:59 volumio sudo[23885]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 08 13:25:59 volumio sudo[23885]: pam_unix(sudo:session): session closed for user root
Jun 08 13:25:59 volumio volumio[26830]: [Vollibrespot] : Track “The Feel Good Drag” loaded
Jun 08 13:25:59 volumio volumio[947]: [SpotifyConnect] Sink acquired
Jun 08 13:25:59 volumio sudo[23894]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Jun 08 13:25:59 volumio sudo[23894]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 08 13:25:59 volumio sudo[23894]: pam_unix(sudo:session): session closed for user root
Jun 08 13:29:26 volumio volumio[947]: [SpotifyConnect] Sink released
Jun 08 13:29:27 volumio volumio[26830]: [Vollibrespot] : Os { code: 104, kind: ConnectionReset, message: “Connection reset by peer” }
