Hi!
I’ve used Volumio before on a RBP Model B+, and then everything worked “ok-ish”. The RBP was getting quite slow, which is why I bought a RBP 3 Model B. I was able to add my Spotify Premium account, and now I can already see my playlists, and play songs from it. I have two problems, from which the first one is the biggest issue by far:
- The search-bar doesn’t work at all. I click on Spotify, and I start typing in the search-bar, but it doesn’t show anything, nothing happens.
- It takes a while before my playlists refresh. For example if I would add a new playlist to my account via the Spotify app, it won’t show up on Volumio until I restart it.
Are these common issues? Because the search-bar was working on my RBP Model B+, so it would be weird if it doesn’t work on RBP 3.
Thanks in advance for your help.
