Hello all.
After a fresh install of 2.141 on RPi 3 with Hifiberry DAC I could not get spotify to work. I can browse spotify fine and chose an artist or a playlist. Playback items appear to be in the queue but playback does not work. Webradio works fine and I get the startup sound ok.
(I too had trouble updating to 2.141 but wound up re-flashing with new image. Hasn’t worked since.)
Rebooted, warm and cold. Tried removing and reinstalling spotify plugin. Same problem. Starting looking at logs and found this:
2017-05-06T22:03:47.718Z - info: [1494108227718] CoreStateMachine::play index undefined
2017-05-06T22:03:47.719Z - info: [1494108227719] CoreStateMachine::setConsumeUpdateService undefined
2017-05-06T22:03:47.720Z - info: [1494108227720] CorePlayQueue::getTrack 1
2017-05-06T22:03:47.726Z - info: Error:
TypeError: Cannot read property ‘service’ of undefined
at Promise._successFn (/volumio/app/statemachine.js:1040:92)
at nextTickCallback (/volumio/node_modules/kew/kew.js:47:28)
at _combinedTickCallback (internal/process/next_tick.js:67:7)
at process._tickCallback (internal/process/next_tick.js:98:9)
2017-05-06T22:03:47.728Z - info: [1494108227727] ------------------------------ 11ms
One thing I noted: running ldd on /usr/bin/spopd it is linked to but cannot find libspotify:
volumio@myplayer:/var/log$ ldd /usr/bin/spopd
linux-vdso.so.1 (0x7eb38000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x76f4c000)
libspotify.so.12 => not found
libglib-2.0.so.0 => /lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0x76e48000)
Seems odd because /usr/bin/spopd is running. So I ran ldconfig and re-ran ldd:
volumio@myplayer:~$ ldd /usr/bin/spopd
linux-vdso.so.1 (0x7ef2f000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x76ee1000)
libspotify.so.12 => /usr/local/lib/libspotify.so.12 (0x76d1f000)
libglib-2.0.so.0 => /lib/arm-linux-gnueabihf/libglib-2.0.so.0 (0x76c1c000)
libgmodule-2.0.so.0 => /usr/lib/arm-linux-gnueabihf/libgmodule-2.0.so.0 (0x76c08000)
looks better. Tried to kill/restart spopd on command line but that did not seem to work. Working after rebooting.
Just sharing this experience in case it helps anyone else. I would need to re-install again to report this more carefully as a bug, but it may be worth looking into whether ldconfig is getting run after new libraries are installed.
Cheers!
-jim
