volumio version: 2.673, rel Dec 1 2019
installed Spotify plugin: 2.0.3
Volumio Spotify Connect2 1.0.5
RPi 3b+, no external soundcard. Hardwired into my network.
All are installed & enabled. Spotify plugin successfully lets me authorize.
I see the spotify icon on the home page, click on it and a page with Spotify icon shows up but nothing on it. grrrrrr.
I had a previous version of Spotify (2.0.1?) and it worked fine.
I am out of options - I de-installed both plugins, added Spotify by itself, rebooted and tried it, deinstalled it, rebooted system, installed Connect2 by itself, rebooted, tried it, deinstalled it, rebooted, installed spotify, then spotify connect2, rebooted, tried it… every permutation failed.
I really don’t want to reinstall Volumio given all the headache I had having it find my NAS drive till I finally said screw it and attached a local SSD.
What is the secret to making this work??? Volumio V3 is NOT an option at this point.
I’ve read a lot of the ‘fixes’ posted 2017, 2018, 2019, and 2020. Tried a few suggestions - the one fix points to a github patch that is NLA.
I really like this app but IMHO, it is really brittle. Suggestions to make spotify work are appreciated (with either spotify plugin)
J
