New user to Volumio. Bought a new rpi3 and Allo Boss DAC which was delivered yesterday. Downloaded v2.310 from the website and loaded onto a micro-sd card.
Volumio setup was smooth and just worked fine. Real kudos to the devs. Made it really simple.
As part of playing with it I figured out how transfer over network some test flac files and they work great.
First observation is the Boss is a noticeable step up audio wise from my previous Chrome Audio setup. However growing annoyance is “popping” noise from the speakers when a new track start. I’ll put that in a different thread…
While playing around the web UI I installed the spotify plugin and loaded my credentials. It completed fine and I turned it on. From the logs it states “info: Spotify credentials grant success” so assume that means credentials are correct.
However from the browser menu, if I click on “My Playlists” nothing happens. In the logs it shows an error “info: Error: This socket has been ended by the other party”. I’ve uploaded log files to logs.volumio.org/volumio/HU4PSnV.html.
The other menus work. However, as soon as I try to play a music track the same thing happens. The web UI doesn’t react and the log file shows the same error above.
What am I doing wrong?
