Spotify Plugin - authorize every restart
is this normal, that I have to authorize the Spotify Plugin Login after every restart of the raspberry pi?
So after every restart I have to go to the plugin setting and click “authorize” and accept this and then it works until i restart again.
Any ideas?
Thanks.
No, it’s not normal.
Make sure Volumio is updated.
If test mode or test mode plugins are enabled, disable these via yourvolumioaddress/dev
Uninstall Spotify plugin(s) and restart Volumio, then reinstall the latest Spotify plugin (currently v 4.0.3).
Thank you very much. I updated volumio and now it works!!
I am having the same issue, I have Volumios latest version… tried every Spotify version available and I have to authorize every time I restart… I have a Rasberry Pi 3b with a Dac pro…Ive restarted every time I delete Spotify and I continue to have this issue… help! lol
Me too. Thanks for bringing this up. I did the plugin uninstallation/reinstallation, and it is still hit or miss whether Spotify is authorized on startup.
Its nice to see Im not the only one… so frustrating… Ive tried everything… but still everytime I
shut it off I have to reauthorize… I have another setup that has Spotify 3.06 and it is flawless…
wish I could install that version.
On which hardware do you run Volumio?
If rPi4, is the datetime correct?
Does Volumio work with Spotify?
yes it does
It is a 3b witha DAC Pro…I can check the date and time… is that important?
I know with Qobuz, Tidal, myVolumio will not connect if the date is off.
Not sure if this is the case, but better safe then sorry.
I will definately give it a try…ty
Thanks @Wheaten The date is correct on my system (RPI/CM4) and it connects to Qobuz on every startup. This is only began after the latest update. I suppose I would need to try a clean installation next.
How do I disable Spotify from launching automatically at login?
How do I stop Spotify from launching on its own?
Was there ever a solution to having to authorize Spotify at every startup? I have the correct time zone set and went through the hassle of a clean installation, but still have this issues. This was never a problem until an update a few months back.
Cheers,
Soren
By coincidence, I discovered that cutting power without first using the power off function in Volumio seems to have the Spotify plugin working correctly on most restarts. Guess it makes shut down easier…
Found this thread as I’m having the same issue.
I have a pi4b using an SD card that will login itself. Meanwhile, my pi5 on nvme will need me to re-authorize almost everytime.
Any update on this? As I seen some recent discussion with likely updates to this plugin to address streaming royalties, I wonder if this will be addressed at the same time.
