I’ve just about finished setting up my DIY player which uses RFID tags to play music. My main music source is Spotify and i’ve got the integration working so I can play songs.
However the NFC plugin only uses ‘Volumio Playlists’. Should the Spotify integration show Spotify playlists in the Volumio playlists section automatically? Or do I need to create a new playlist and manually consolidate the 2?
If that’s the case if anyone has any brainwaves on sync’ing them I’d really appreciate it.
Asking as i’m not sure if the spotify plugin should do that automatically or not.
