Yep it seems to be working again and more stable than the previous version. (With previous version I mean the version before Spotify made changes)
Well done team.
@devgianlu , @volumio , @balbuze
Well done team.
After reinstal of 4.2.2 everything is working.
Hi everyone,
Iāve been using Volumio with the Spotify plugin for quite some time now, and Iāve always faced the same issue: āSpotify playback stops automatically after a few minutes/hoursā, and I have to manually press Play again.
The only version that never had this issue, was version: 4.1.3 . I used it for several months without a single interruption ā it was perfect.
However, two days ago, music suddenly stopped and I couldnāt get it to play again. The Play button wouldnāt respond at all, and on Spotify i cant play too! Thatās when I updated to the latest and actual plugin version (4.2.2), which fixed the Play button issue, but unfortunately, the problem of playback stopping after a few hours came back.
So in short:
Is there any way to:
Thanks a lot for your help!
oh man
Thank You, Spotify works perfect again!
Updated and working againm thanks !!
But, is it me or does the album not show in volumio anymore when playing through spotify ? Or has it never been doing that ? (using spotify for years on volumio but canāt recall)
And, I see the player in spotify now as āgo-librespot -myname-ā instead of just myname as per volumio setting. Anything I can do there ?
Thanks !!!
I knew this method and saved the installation few times by uninstalling the Spotify plugin and all the reboots but it comes back over and over.
I tend to see a pattern. If the electric company does some maintenance work cutting the electricity, the Spotify plugin tends to fail. Not always but sometimes.
Few times I had to reinstall the whole Volumio image and start from scratch.
The current issue is that I can see the Volumio device through Spotify but when I try to connect it kicks me out of it.
There are some serious issues with this current Spotify plugin.
