My Volumio has worked perfectly for 1 year.
Now it is shifting numbers by itself one number på second!
When playing web radio all is fine.
The shifting is only when using Spotify connect plugin. Witch is my preferred method of playing music.
Any ideas?
I have tried to start over with a new installation on a new memory card, with the same result.
I had the same problem. Found a solution here:
Thanks a lot! I’m happy and playing again
