I’ve installed and activated “Spotify 3.0.3” and “Volumio Spotify connect2 1.0.5”.
Both are activated, I can see and browse spotify but volumio is not playing.
I cannot play either any radio or my music files.
I did sevral reboot…
Any ideas ?
There is a version 3.0.6. out, that is working (at least for me) without issues.
Uninstall v3.0.3 - reboot - install v3.0.6. - reboot then it should work
I’ve installed 3.0.3 'cause it was the only one proposed on my web GUI.
Did you installed 3.0.6 with SSH and a Github ? (what I did for “Volumio Spotify connect2 1.0.5”)
Volumio Spotify connect2 1.0.5 and “Spotify” modules are both mandatory to run Spotify? aren’t-they ?
No, 3.0.6 is available from within Volumio. In any case, best to follow @Josh2000 's advice and remove all Spotify plugins, reboot, then install the latest plugin. I would add, do a final power off and power on after the install.
