Spotify hangs after a while
I’m a Premium user of spotify and use the spotify plug-in to connect with Volumio. After a while the sound is cut off. It seems that it is still running, but the only solution I have is to restart volumio and spotify. This happens several times a day.
Anybody the same experience?
Is this Spotify or Spotify Connect?
I’m using spotify connect 2
Could you share some logs?
Either from the /dev page using the livelog feature or via ssh.
# Volumio logs
journalctl -f
# vollibrespot logs
journalctl -f  -u volspotconnect2.service
Note you might need sudo before these commands depending on the version of Volumio your running
Is this what you want?
http://logs.volumio.org/volumio/tEAvkg0.html
That is a start yes, but that doesn’t really show anything abnormal.
There are a few things that might need some investigation, but don’t see anything explicitly wrong.
Nov 28 19:05:12 volumio volumio[1149]: [Vollibrespot] : couldn't parse packet from V4(192.168.11.22:5353): query type 65 is invalid
Nov 28 19:05:13 volumio volumio[1149]: [Vollibrespot] : couldn't parse packet from V4(192.168.11.22:5353): query type 65 is invalid
Could you try logging in via SSH and running the commands posted above the next time you encounter this issue? That makes it easier to debug…
is this sufficient ordo you need a longer log.
Dec 03 20:20:46 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:20:51 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:20:56 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:01 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:06 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:11 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:14 volumio volumio[965]: error: error
Dec 03 20:21:16 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:21 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:26 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:31 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:36 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:41 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:46 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
Dec 03 20:21:51 volumio pivoyager_ups.sh[686]: Status(13): pg stat2 5v
-- Logs begin at Thu 2020-12-03 20:12:59 CET. --
Dec 03 20:15:24 volumio systemd[1]: Starting Volspotconnect2 Daemon...
Dec 03 20:15:24 volumio systemd[1]: Started Volspotconnect2 Daemon.
Dec 03 20:15:24 volumio volumio[1165]: vollibrespot v0.2.2 cd96399 2020-10-07 ($
Dec 03 20:15:24 volumio volumio[1165]: Reading Config from "volspotify.toml"
Dec 03 20:15:24 volumio volumio[1165]: [Vollibrespot] : Using Alsa backend with$
Dec 03 20:15:24 volumio volumio[1165]: [Vollibrespot] : Failed to register IPv6$
Hmm, no not really - are you sure these logs are from when you were playing some music on Spotify Connect and it suddenly dropped out as you describe in your first post?
Ideally you’d have to get terminal access to the pi (either via ssh or add a keyboard/monitor to the pi) and then run the journalctl commands from a few posts up.
Hello ,
I have collected some logs as you requested. Where can I put them? I can’t see a possibilty to add a file to a message.
If it’s a text file, you should be able to attach it to the post either by drag and drop, or clicking the upload icon in the formatting header.
PS: allowed file types are (jpg, jpeg, png, gif, zip, txt)
I’m not allowed to upload files ( new user )?
volumio_log_13122020.txt (78.3 KB)
Thanks for the response.
I hope you can find something.
