Spotify Genre Jazz/Blue
I can not find the Jazz/Blue genre in Spotify. Is it correct or am I the one who can not find it?
Regards
Daniel
I agree, it does not appear under ‘genre.’ Playlists shown though if you search.
Can I expect a correction from Volumio or does this depend on Spotify?
This has already been corrected, but it looks as though we are waiting for the updated plugin to be made available.
Edit: if you’re particularly desperate for the missing genres, then you could make manual edits yourself (carefully!): https://volumio.org/forum/how-use-spotify-t4339-10.html?hilit=spotify%20genres
Thank you! It worked ok !!!
