I have noticed that volumio is bypassing my explicit filter on my Spotify and decides to play them anyway. The explicit song avoidance is defined on my Spotify app. Is there a workaround for this?
I don’t have a solution per say. It sounds like you are using the Spotify plugin not the Spotify Connect plugin.
The only workaround would be to use the Spotify connect plugin instead as you would be using the Spotify app instead and therefore using Spotify settings.
Hello, thanks for the response. I have checked and the plugin that is active is the “Volumio Spotify Connect2”. The other spotify plugin is not active on my end.
Oh, that’s so weird. I don’t really know then. I would have assumed that if you’re using the Spotify App to play your music Volumio has no influence on it. Sorry I couldn’t help, maybe someone else can.
I’ve realized that this is controlled by the plugin and not volumio itself. I think this topic can be deleted. Thanks.
