Hi @balbuze, @ashthespy
Recently i tried to manually install the Spotify plugin on the latest beta version of the buster image for x86.
My system is the MinixZ64 with 64-bit 3.053 buster image (Volumio 3 Buster Beta for X86).
As the automatic plugin installation is not yet available, i tried the manual install steps as mentioned in
But first i get an error
Sorry, current device (arch = x86_64) is not supported! Terminating installation!
Then i tried to do the install using the install.sh. I edited the downloaded install.sh and changed the VLS_BIN to try the vollibrespot-aarch64.tar.xz and the vollibrespot-i686.tar.xz.
But no success so far. I keep getting the error
install.sh: line 68: ./vollibrespot: cannot execute binary file: Exec format error
and
volumio@volumio:/data/plugins/music_service$ systemctl status volspotconnect2.service
● volspotconnect2.service - Volspotconnect2 Daemon
Loaded: loaded (/etc/systemd/system/volspotconnect2.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2021-03-06 20:16:40 UTC; 12s ago
Process: 2494 ExecStart=/bin/bash /data/plugins/music_service/volspotconnect2/startconnect.sh (code=exited, status=126)
Main PID: 2494 (code=exited, status=126)
Mar 06 20:16:40 volumio systemd[1]: volspotconnect2.service: Service RestartSec=2s expired, scheduling restart.
Mar 06 20:16:40 volumio systemd[1]: volspotconnect2.service: Scheduled restart job, restart counter is at 4.
Mar 06 20:16:40 volumio systemd[1]: Stopped Volspotconnect2 Daemon.
Mar 06 20:16:40 volumio systemd[1]: volspotconnect2.service: Start request repeated too quickly.
Mar 06 20:16:40 volumio systemd[1]: volspotconnect2.service: Failed with result ‘exit-code’.
Mar 06 20:16:40 volumio systemd[1]: Failed to start Volspotconnect2 Daemon.
Is there anyway to make the spotify plugin work on the buster beta x86 builds.
