Spotify connect2 pauze after song
I am using the Spotify Connect2 app made by Balbuze.
After every track I need to hit the play button because the next track doesn’t start.
Can you help me with this problem?
Thanks!
Do you use native spotify app to control wolumio with spotvolconnect2?
I have exactly the same problem using the native app to control. I have updated volumio and all plugins and everything else works fine other than it will only play one song in a row.
Mike
We’re working on that
Same problem here. I’ve uninstalled and reinstalled the plugin and the problem persist.
All users,
Yes there is a problem with the plugin.
We are working to solve it asap.
There is no interest to remove and reinstall the plugin several times. Don’t waste your time with that
And please, stop creating new thread about this plugin. Use one of already existing.
