I have two Raspberry Pis running Volumio on my home network. From my Spotify app I can see and stream to my first Volumio device but not to the second one. I sometimes see the second Volumio in Spotify Device list, but I was never able to select it successfully. Any suggestion on how to debug this?
Plugin version: 1.0.3
Volumio version: 2.779
Welcome to Volumio francesco :).
Are all of your devices on a single network (in my house, I have a couple of networks to ensure good coverage)? I would think the mobile & Volumio device would need to be on the same network.
Hi! Yes they are. All on the same network. I even though that was the problem…
What is the Dac for both device? Same? Hardware mixer?
Hi, the RPi working with Spotify Connect mounts a Allo MiniBoss. The RPi that is not working with Spotify Connect has no DAC directly attached but is connected via USB to the AudioEngine D1 DAC which I use as headphone amp. It works fine except for Spotify Connect.
I suspect a problem with the volume mixer. Does your Dac provide a hardware mixer?
A log would help “journalctl -f’” to see what happens when you try to connect.
Btw, can you try to set a software mixer in Volumio and see how it goes.
You’re right!
Jun 25 11:29:29 deskbedroom volumio[30211]: thread 'main' panicked at 'Error setting up mixer!: Error("snd_mixer_attach", Sys(ENOENT))', /build/cache/git/checkouts/librespot-6f197fd632ef9380/659de68/playback/src/mixer/alsamixer.rs:184:9
I tried to set software and none but I keep getting the same error.
If you set the mixer to Software, then it should not be trying to find use alsa’s snd_mixer_attach
Could you share logs of just vls? (journalctl -o cat -u volspotconnect2.service
) after you’ve set up the Software mixer in volumio playback options?
Thanks! It works! Now after I selected software
instead of hardware
, it started working (probably it didn’t switch correctly the first time…). What about the loss of quality it mentions in the popup? Is that significant…?
Select the Mixer Type: None = No volume control, Software = Volume control but loss of Audio Quality, Hardware = Best of both worlds, provides ability to change volume without loss of quality
Well, without looking at the logs, I can’t comment if your issue is just a misconfigured mixer, or if it’s that your device doesn’t have a hardware mixer. Would you know?
That being said, I’ve been noticing an increase in the number of USB DACs having wrong mixers names/setups.
