Spotify Connect
Is anyone else having issues with Spotify connect? I installed the Spotify connect 2 plugin. Everything was working awesome and then a few days ago my devices either wouldn’t connect or they would drop out.
My setup:
-Pi 3 B
-Hifiberry Digi+Pro
Cheers, James
Spotify made a change. You need the last version of the plugin to be able to use it
okay, where do I get the plugin and how do I install it? I’m guessing that Volumio must have some “official” plugin in the works. Should I just hold out for that?
Thank you for helping me out
Cheers, James
ios-spotify-connect-issue-t9193.html
