I am using Spotify Connect with MiniDSP SHD preamp which uses Volumio for streaming. The interface works great but the signal will not hold consistently. Sometimes it will hold for an hour. But usually 3-10 minutes. When it drops the signal you just press the “select device” option and select minidsp again and it will work again. Until it drops again. So clearly the technology works but something is causing it to drop the signal.
Any suggestions? It’s really frustrating.
