hello all, first time using Volumio on the Allo DigiOne player.
i have installed the plugin, Spotify Connect2, and it is working BUT…
Volumio device shows only on my desktop Spotify app and of course, i can select it for streaming.
then, only then, do i see Volumio in other apps running on a laptop or another Android devices.
so the question is: what is unique about the desktop Spotify app? -
it was in fact the desktop where i first connected to Volumio and installed the plugin.
and i did not have to enter my Spotify credentials. so how did the plugin work?
thank you for any help and insights…
hong
