Volumio Information
Volumio Version: 2.907
Hardware: Raspberry Pi 4 8GB
DAC: Schiit Asgard 3 w/ Multibit
I’m able to see my volumio device, but unable to connect. I’m seeing mixer errors…
What I’m seeing in the logs:
Jul 24 15:11:04 asgard systemd[1]: volspotconnect2.service holdoff time over, scheduling restart.
Jul 24 15:11:04 asgard systemd[1]: Stopping Volspotconnect2 Daemon…
Jul 24 15:11:04 asgard systemd[1]: Starting Volspotconnect2 Daemon…
Jul 24 15:11:04 asgard systemd[1]: Started Volspotconnect2 Daemon.
Jul 24 15:11:04 asgard volumio[1943]: vollibrespot v0.2.2 cd96399 2020-10-07 (librespot 08d8bcc 2020-10-07) – Built On 2020-10-07
Jul 24 15:11:04 asgard volumio[1943]: Reading Config from “volspotify.toml”
Jul 24 15:11:04 asgard volumio[1943]: [Vollibrespot] : Using Alsa backend with device: plughw:5
Jul 24 15:11:04 asgard volumio[1943]: [Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: “No such device” }
Jul 24 15:11:49 asgard volumio[1943]: [Vollibrespot] : Connecting to AP “guc3-accesspoint-a-3351.ap.spotify.com:443”
Jul 24 15:11:49 asgard volumio[1943]: [Vollibrespot] : Authenticated as “USER” !
Jul 24 15:11:49 asgard volumio[1943]: [Vollibrespot] : Setting up new mixer: card:hw:5 mixer:PCM index:0
Jul 24 15:11:49 asgard volumio[1943]: [Vollibrespot] : Alsa min-db is not SND_CTL_TLV_DB_GAIN_MUTE!!
Jul 24 15:11:49 asgard volumio[1943]: [Vollibrespot] : Alsa Mixer info min: 0 (MilliBel(0)[dB]) – max: 0 (MilliBel(0)[dB]) HW: false
Jul 24 15:11:49 asgard volumio[1943]: [Vollibrespot] : Switching to linear volume mapping, control range: MilliBel(0)
Jul 24 15:11:49 asgard volumio[1943]: [Vollibrespot] : Using alsa sink
> Jul 24 15:11:49 asgard volumio[1943]: thread ‘main’ panicked at ‘Couldn’t get current volume: Error(“snd_mixer_selem_get_playback_volume”, Sys(EINVAL))’, /build/cache/git/checkouts/librespot-6f197fd632ef9380/08d8bcc/playback/src/mixer/alsamixer.rs:94:14
Jul 24 15:11:49 asgard volumio[1943]: stack backtrace:
Jul 24 15:11:49 asgard volumio[1943]: 0: 0xa2633c - backtrace::backtrace::libunwind::trace::hae21a072c81e5842
Jul 24 15:11:49 asgard volumio[1943]: at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.46/src/backtrace/libunwind.rs:86
Jul 24 15:11:49 asgard volumio[1943]: 1: 0xa2633c - backtrace::backtrace::trace_unsynchronized::h0f9b260087e46e47
Jul 24 15:11:49 asgard volumio[1943]: at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.46/src/backtrace/mod.rs:66
Jul 24 15:11:49 asgard volumio[1943]: 2: 0xa2633c - std::sys_common::backtrace::_print_fmt::hbf1a59173a7860c3
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/sys_common/backtrace.rs:78
Jul 24 15:11:49 asgard volumio[1943]: 3: 0xa2633c - <std::sys_common::backtrace::_print::DisplayBacktrace as core::fmt::Display>::fmt::he1a5d6f378e506c4
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/sys_common/backtrace.rs:59
Jul 24 15:11:49 asgard volumio[1943]: 4: 0xa46d5c - core::fmt::write::hb37ae5a5e0b70623
Jul 24 15:11:49 asgard volumio[1943]: at src/libcore/fmt/mod.rs:1076
Jul 24 15:11:49 asgard volumio[1943]: 5: 0xa1fc64 - std::io::Write::write_fmt::ha24bb3f5a858327b
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/io/mod.rs:1537
Jul 24 15:11:49 asgard volumio[1943]: 6: 0xa28974 - std::sys_common::backtrace::_print::h47b03aa1342833e3
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/sys_common/backtrace.rs:62
Jul 24 15:11:49 asgard volumio[1943]: 7: 0xa28974 - std::sys_common::backtrace::print::h2217cbc390250439
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/sys_common/backtrace.rs:49
Jul 24 15:11:49 asgard volumio[1943]: 8: 0xa28974 - std::panicking::default_hook::{{closure}}::h179f5229ea1c8e30
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/panicking.rs:198
Jul 24 15:11:49 asgard volumio[1943]: 9: 0xa28640 - std::panicking::default_hook::h46ab82039cbc65eb
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/panicking.rs:217
Jul 24 15:11:49 asgard volumio[1943]: 10: 0xa29054 - std::panicking::rust_panic_with_hook::h7326c48419bc7c33
Jul 24 15:11:49 asgard volumio[1943]: at src/libstd/panicking.rs:526
Jul 24 15:11:49 asgard volumio[1943]: 11: 0xa28c54 - rust_begin_unwind
