In Spotify it shows up in the app, tries to connect but then stops.
The raspberry pi got a new fresh install of volumio 3. As well I’ve reinstalled the plugin. Restarted the device and restarted the network. And the spotify app.
Fresh reboot.
Trying to play trough Spotify connect to Volumio.
It shows up in the app, Mac and iPhone. But cannot connect to Volumio.
Spotify continues to play on another device.
Suddenly it works. Spotify connects to volumio. Then I didn’t have any sound. Played around with settings. After restart it worked.
Looks like everything you change in the plugin needs a restart. I’ve had it with normalization. This is now turned off in the plugin, on in the basic settings.
If I may be permitted to hijack… same issue here, and it doesn’t seem solved to me?
I have a Spotify Premium account. Freshly installed on a new Pi Zero W, with Hifiberry DAC+. I have two Spotify plugins installed, but only enabled Volumio Spotify Connect2. It’s currently set to Multi-user device - I tried setting it to only my personal account, but after restarting Volumio, Spotify on both my android phone and Windows10 laptop did not even see the device… Now that it’s set to Multi-user, Spotify recognizes it but doesn’t connect. Any idea on how to solve this?
Did anyone solve this?
I have an Audiophonics ES9038Q2M DAC HAT… & Volumio 3.
Installed - removed access to Vlumio, reinstalled - reanabled.
installed both Spotify plugins (like I did with Volumio 2)
I can play Spotify from Volumio but not the other way around.
I see the “Volumio” in Spotify Connect, but when I choose it, it does not go to play out there.
I tried to set uninstall and reinstall the plugins (both) for Spotify & re-connecting the email & password
Restarted Volumio
(that would set it back to “hardware”)
I set it again to software, saved
Disableed and Reenabled plugins
Restarted Spotify
I see “Volumio” as playback option in Spotify, but it only lights green for a second.
Sameproblem: I can play Spotify from Volumio but I cannot use “Spotify Connect”.
One interesting observation - when I choose Volumio in Spotify - Volumio webinterface writes “Spotify Connect is Active” as a banner for 2 seconds. See here
