I just installed the touchscreen plugin (following the Volumio How-To guide to install touchscreen and plugin) and now, I cannot get Spotify Connect to work anymore. Some notes about my configuration and what I have tested:
- Raspberry Pi 4B with official 7" Touchscreen
- RPi and touchscreen are powered separately
- Spotify Connect still works fine on the other Volumio device in my house (RPi 2B)
- Airplay seems to work fine on both units
- I am running Volumio Premium on both RPi’s
- Spotify Connect was working great on this RPi before I set up the touchscreen.
Any help to get Spotify working again is much appreciated! The Volumio Log for when I try to connect via Spotify Connect (through the app on my phone) is below:
[Vollibrespot] : Connecting to AP "ap-guc3.spotify.com:443"
[Vollibrespot] : Authenticated as "==removed for privacy==" !
[Vollibrespot] : Setting up new mixer: card:hw:5 mixer: index:0
thread 'main' panicked at 'Couldn't find simple mixer control for ,0', /build/cache/git/checkouts/librespot-6f197fd632ef9380/08d8bcc/playback/src/mixer/alsamixer.rs:39:44
stack backtrace:
0: 0x9e2040 - std::backtrace_rs::backtrace::libunwind::trace::h4e6fc6cdc5d76862
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/../../backtrace/src/backtrace/libunwind.rs:90:5
1: 0x9e2040 - std::backtrace_rs::backtrace::trace_unsynchronized::h1c665adaaf480d86
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/../../backtrace/src/backtrace/mod.rs:66:5
2: 0x9e2040 - std::sys_common::backtrace::_print_fmt::h39ff02745027e048
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:67:5
3: 0x9e2040 - ::fmt::hc83ae421f857c6ae
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:46:22
4: 0xa036a4 - core::fmt::write::h59f33d28fc1a9cf5
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/fmt/mod.rs:1092:17
5: 0x9dafec - std::io::Write::write_fmt::h96774110acd52d88
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/io/mod.rs:1572:15
6: 0x9e474c - std::sys_common::backtrace::_print::h28b9431057012c44
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:49:5
7: 0x9e474c - std::sys_common::backtrace::print::h28173b7ebfe4a4ac
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:36:9
8: 0x9e474c - std::panicking::default_hook::{{closure}}::h12f82aa3def34336
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:208:50
9: 0x9e412c - std::panicking::default_hook::hee29440c29c1cc2e
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:225:9
10: 0x9e4dac - std::panicking::rust_panic_with_hook::he7d3b6e3eee77e72
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:591:17
11: 0x9e4928 - std::panicking::begin_panic_handler::{{closure}}::h7faba6b3632756a6
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:497:13
12: 0x9e25bc - std::sys_common::backtrace::__rust_end_short_backtrace::hdde0f982a7a71ce9
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:141:18
13: 0x9e4870 - rust_begin_unwind
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:493:5
14: 0x4be21c - core::panicking::panic_fmt::h97b6949f75a63095
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/panicking.rs:92:14
15: 0x4be0a4 - core::option::expect_failed::h4183cd8fa1675d39
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/option.rs:1321:5
16: 0x5e424c - ::open::h987add80eb0ef508
17: 0x5107c8 - librespot_playback::mixer::mk_sink::h0d1999bb15de8a1f
18: 0x4e14e4 - ::poll::h19799562239aa72c
19: 0x4fe0a0 - futures::task_impl::std::set::h0ef71bfab756f27d
20: 0x5187b8 - std::thread::local::LocalKey::with::hb3c749d82f06f5c0
21: 0x4f0710 - tokio_current_thread::Entered
::block_on::hac3e29a0a4da8120
22: 0x518178 - std::thread::local::LocalKey::with::h78cb87ff6f4c2b7d
23: 0x52dcd4 - tokio_timer::clock::clock::with_default::hb0853b95f60f0630
24: 0x4ea9f4 - tokio::runtime::current_thread::runtime::Runti
me::block_on::h239cb8d546240575
25: 0x4e4258 - vollibrespot::main::hf11cedd7d8a3be51
26: 0x517500 - std::sys_common::backtrace::__rust_begin_short_backtrace::ha48b0377a890cb6d
27: 0x517720 - std::rt::lang_start::{{closure}}::h120c4b14d2445a8e
28: 0x9e5198 - core::ops::function::impls:: for &F>::call_once::hb7f0eab2b8615017
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/ops/function.rs:259:13
29: 0x9e5198 - std::panicking::try::do_call::h2c625414401a1a99
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:379:40
30: 0x9e5198 - std::panicking::try::h09167d835e285a07
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:343:19
31: 0x9e5198 - std::panic::catch_unwind::hdff19ee37d8421eb
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panic.rs:431:14
32: 0x9e5198 - std::rt::lang_start_internal::h835544f25e1ef31c
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/rt.rs:51:25
33: 0x4e5a08 - main
34: 0xb6bc3718 - __libc_start_main
volspotconnect2.service: Main process exited, code=exited, status=101/n/a
volspotconnect2.service: Failed with result 'exit-code'.
volspotconnect2.service: Service RestartSec=2s expired, scheduling restart.
volspotconnect2.service: Scheduled restart job, restart counter is at 4.
Stopped Volspotconnect2 Daemon.
Started Volspotconnect2 Daemon.
vollibrespot v0.2.3 769ce77 2021-06-04 (librespot 08d8bcc 2020-10-07) -- Built On 2021-06-04
Reading Config from "volspotify.toml"
[Vollibrespot] : Using Alsa backend with device: volumio
[Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: "No such device" }
error: error
