Spotify connect issues
I’m having a lot of trouble getting Spotify Connect to work. Most often I’m not able to connect using both an iPhone, Samsung S21 or Windows 11 laptop.
When I am able to connect, or when it says it’s connected, music will still not play. I’ve accessed the dev page and generated some logs, which can be found here:
http://logs.volumio.org/volumio/TraPDHS.html
Main error I’ve found in the log is this:
level=warning msg="failed handling dealer request" error="failed loading current track (skip prev): failed creating stream for spotify:track:7s3g6VVfYaqmyL24uzJSEV: failed retrieving audio key: failed retrieving aes key with code 1"
I’m using Volumio 3.874 and currently the beta connect plugin 4.3.2, but I’m having similar issues with the stable version.
What could be wrong? And, since I’m new. What could I do to troubleshoot further?
This issue only affects new (december 2025) Spotify accounts. No problems with native Spotify devices like the Wiim DAC.
Is there any fix for this?
