Thank you for the great combination of Volumio and Spotify I enjoy to hear music almost every day… BUT, suddenly from 2 hours ago, when I tried to connect with Spotify app from my iPad or MacBook, Volumio started to reject my connection request. It looks once accepted, but then failed in a 5 second.
Below is the log file generated by the command “journalctl -f -o cat”
The log file said:
"thread 'main' **panicked** at 'Spotify servers returned an error."
root@rotate:/home/volumio# journalctl -f -o cat
volspotconnect2.service holdoff time over, scheduling restart.
Stopping Volspotconnect2 Daemon...
Starting Volspotconnect2 Daemon...
Started Volspotconnect2 Daemon.
vollibrespot v0.2.2 cd96399 2020-10-07 (librespot 08d8bcc 2020-10-07) -- Built On 2020-10-07
Reading Config from "volspotify.toml"
[Vollibrespot] : Using Alsa backend with device: plughw:2
[Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: "No such device" }
[Vollibrespot] : Connecting to AP "gae2-accesspoint-b-vfq3.ap.spotify.com:443"
[Vollibrespot] : Authenticated as "21n25wukzzqgsdponevurtrrq" !
[Vollibrespot] : Setting up new mixer: card:hw:2 mixer:Master index:0
[Vollibrespot] : Alsa min-db is not SND_CTL_TLV_DB_GAIN_MUTE!!
[Vollibrespot] : Alsa Mixer info min: 0 (MilliBel(-12750)[dB]) -- max: 255 (MilliBel(0)[dB]) HW: true
[Vollibrespot] : Using alsa sink
[Vollibrespot] : Country: "JP"
[Vollibrespot] : Metadata pipe established
[Vollibrespot] : Event: Volume { volume_to_mixer: 19660 }
[SpotifyConnect] <Volume> 29.999237048905165
[SpotifyConnect] Volume: Spotify:29.999237048905165 Volumio: 30
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: SessionActive { became_active_at: 1608022750171 }
[Vollibrespot] : SessionActive!
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 117025201139629847069006936459738638492, audio_type: Track } }
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 117025201139629847069006936459738638492, audio_type: Track } }
[SpotifyConnect] <DeviceActive> A connect session has begun
[SpotifyConnect] <PlaybackActive> Device palyback is active!
[SpotifyConnect] Currently active: volspotconnect2
[SpotifyConnect] Not requsting volumioStop on our own service
[SpotifyConnect] Vollibrespot Active
[SpotifyConnect] Pushing new state :: true
thread 'main' panicked at 'Spotify servers returned an error. Restart librespot.', /build/cache/git/checkouts/librespot-6f197fd632ef9380/08d8bcc/core/src/mercury/mod.rs:200:13
stack backtrace:
0: 0xa5b33c - backtrace::backtrace::libunwind::trace::hae21a072c81e5842
at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.46/src/backtrace/libunwind.rs:86
1: 0xa5b33c - backtrace::backtrace::trace_unsynchronized::h0f9b260087e46e47
at /cargo/registry/src/github.com-1ecc6299db9ec823/backtrace-0.3.46/src/backtrace/mod.rs:66
2: 0xa5b33c - std::sys_common::backtrace::_print_fmt::hbf1a59173a7860c3
at src/libstd/sys_common/backtrace.rs:78
3: 0xa5b33c - <std::sys_common::backtrace::_print::DisplayBacktrace as core::fmt::Display>::fmt::he1a5d6f378e506c4
at src/libstd/sys_common/backtrace.rs:59
4: 0xa7bd5c - core::fmt::write::hb37ae5a5e0b70623
at src/libcore/fmt/mod.rs:1076
5: 0xa54c64 - std::io::Write::write_fmt::ha24bb3f5a858327b
at src/libstd/io/mod.rs:1537
6: 0xa5d974 - std::sys_common::backtrace::_print::h47b03aa1342833e3
at src/libstd/sys_common/backtrace.rs:62
7: 0xa5d974 - std::sys_common::backtrace::print::h2217cbc390250439
at src/libstd/sys_common/backtrace.rs:49
8: 0xa5d974 - std::panicking::default_hook::{{closure}}::h179f5229ea1c8e30
at src/libstd/panicking.rs:198
9: 0xa5d640 - std::panicking::default_hook::h46ab82039cbc65eb
at src/libstd/panicking.rs:217
10: 0xa5e054 - std::panicking::rust_panic_with_hook::h7326c48419bc7c33
at src/libstd/panicking.rs:526
11: 0x761e60 - std::panicking::begin_panic::h32bd0337e6f60c80
12: 0x777670 - librespot_core::mercury::MercuryManager::dispatch::hfc40927a9e25f6f4
13: 0x7548e4 - librespot_core::session::Session::dispatch::h443b33171bd0a54b
14: 0x755a94 - <librespot_core::session::DispatchTask<S> as futures::future::Future>::poll::h44e39a909986a977
15: 0x6ec544 - <futures::future::join::Join<A,B> as futures::future::Future>::poll::he539c98ccf64057e
16: 0x74f884 - <futures::future::map::Map<A,F> as futures::future::Future>::poll::h22f2ddba187c7f88
17: 0x7aa408 - <futures::future::map_err::MapErr<A,F> as futures::future::Future>::poll::h271e84c19710286e
18: 0x54352c - futures::task_impl::std::set::h73f64ee501dae51c
19: 0x5338f8 - tokio_current_thread::CurrentRunner::set_spawn::hc01b74ea59b01474
20: 0x556070 - tokio_current_thread::scheduler::Scheduler<U>::tick::h4e6f96fbe4f47161
21: 0x533ad4 - tokio_current_thread::Entered<P>::block_on::h339073902a399eb7
22: 0x557e00 - std::thread::local::LocalKey<T>::with::hff64c13ccfec5327
23: 0x56420c - tokio_reactor::with_default::h7ef12e65cb103d2f
24: 0x5379f8 - tokio::runtime::current_thread::runtime::Runtime::block_on::h043f136d6b8cf48f
volspotconnect2.service: main process exited, code=exited, status=101/n/a
Unit volspotconnect2.service entered failed state.
25: 0x57d2c8 - vollibrespot::main::h02a0d49d4cc5eaa6
26: 0x564f18 - std::rt::lang_start::{{closure}}::h279cd2b7929fdba7
27: 0xa5e404 - std::rt::lang_start_internal::{{closure}}::he93bfc404849b78a
at src/libstd/rt.rs:52
28: 0xa5e404 - std::panicking::try::do_call::h6e9e98f4078affb0
at src/libstd/panicking.rs:348
29: 0xa5e404 - std::panicking::try::h2e68d4f7f799a6df
at src/libstd/panicking.rs:325
30: 0xa5e404 - std::panic::catch_unwind::h8880a4c07cc66391
at src/libstd/panic.rs:394
31: 0xa5e404 - std::rt::lang_start_internal::hf4ae2140248bf16b
at src/libstd/rt.rs:51
32: 0x57dd84 - main
33: 0x76ca1294 - __libc_start_main
[Vollibrespot] : EventSender disconnected
[SpotifyConnect] <PlaybackInactive> Device palyback is inactive
[SpotifyConnect] Device Session is_active: true
[SpotifyConnect] <SinkInactive> Sink released
^C
Volumio version: 2.863 20 Nov
Rpi 3+, Allo Katana DAC with Digital mixer, touch sreen plug-in added.
